AirStreamJoe
- Jan 16, 2020
- 30
Hello everyone, been watching a ton of Will Prowse's videos regarding inverter/charger/battery setups and really enjoy his information, not sure how I landed here, but I'm happy I did!
I purchased a 1975 31 foot Airstream a few years ago and have just finished building the new frame from 316L Stainless. Now I am moving on to constructing the electrical system. Keep in mind I only have electrical experience from reading the internet for the last 4 months and talking to other folks and watching a zillion YouTube videos. I have selected all the parts for the Airstream, perhaps someone with a bit more electrical knowledge could help me get this baby put together. I am a computer programmer as a career and have programmed some custom software for my Nvidia Jetson TX2 arm based computer in order to have automated control over my level tank level, lights on / off / dimming, coach orientation via gyroscope, gps, water pumps, window tint, self leveling, temperature readings, as well as some security features.
I don't need this to be a 'can run off grid forever machine' the solar just supplements my 'quite time' while I work on the computer mainly.. I could even use the Bose headphones while I program with the gen-set charging up for a bit if required.. but I just wanted to state this doesn't need to be a sustainable 'off-grid' setup, but able to run the loads requested for the times requested without shore power 100% of the time for periods of about 5 days max ( a work week ). Also bear in mind I will never run every electrical item at the same time.
The following are the items I have considering putting into the system, the generator, as well as a list of electrical appliances that need to be able to be run and their estimated run times. I know I am missing from the list -- fuses, and cuttoffs as well as the wiring / gauge as well as potentially more..
"Tow Vehicle"
2017 Ford F250 /w 6.0 PowerStroke 2 Heavy Duty Alternators ( I do not think they're made for lithium specifically tho )
"The Electrical System Components"
LiFePO4 Battery Isolation Manager -- ( for alternator charging? Should I use a victron product, do they have one? )
Victron Energy Inv/Chgr, Quattro, 12V 5000W 200A -- ( should I use 2 smaller 24V3000Watt in split phase to get my 220V outlet?? )
Victron Color Control GX
6 x Renogy 100 Watt 12 Volt Extremely Flexible Monocrystalline Solar Panel
Victron SmartSolar MPPT 250/100 - Tr Solar Charge Controller 250V 100A with Bluetooth
BMV-712 Smart
VE.Bus Smart Dongle
"Battery Bank"
10 x Valence U27-12XP ( 1380 amp hours total -- but used, so lets say around 1000 to low ball it )
"The Generator"
Cummins Onan 2500 LP -- Propane Powered
"Electric Devices To Be Run with estimated run times"
MTI Industries 30-442-P-WT Propane Gas Alarm -- 90mA @ 12V -- 24 hours a day
weBoost Drive 4G-X RV 470410 Cell Phone Signal Booster -- 8 Watts @ 110V -- 24 hours a day
Nvidia Jetson TX2 - ARM based super-computer -- 10-12 Watts @ 12V -- 24 hours a day
Vitrifrigo DW250IXN4 Upper Refrigerator & Lower Freezer -- 85 watts @ 12V
or
-- 85 watts @ 110V -- 24 hours a day
LG 34BK95U-W UltraFine Monitor -- 70 watts @ 110V -- 8 hours a day
2x ABSOLUTE SERIES™ LED Flexible Strip - 99 CRI - 16 ft Reel -- 3.75 amps @ 12V -- 3 - 5 hours per day
Splendide WD2100XC White Vented Combo Washer/Dryer -- 1300 watts @ 110v -- 2 hours every other day
Breville the Barista Express Espresso Machine -- 1600 watts @ 110v -- 20 mins a day
2x Dometic B59516.XX1C0 Brisk II Polar White Air Conditioner -- 1725 watts @ 110V -- location dependent
Maxxair 0007000K MaxxFan Deluxe Fan with Remote -- 60 watts @ 12V -- location dependent
UP6/E Water Pressure Pump -- 120 watts @ 12V -- 30 mins day
Desktop Computer -- 1000 watt(max) @ 12V -- 2 hours a day
Mr. Stream SAH3000 ( Steam Shower ) -- 3000 watts @ 220v -- 20-30 mins a day
Lineal Adjustable Base -- 250 watts @ 110v -- 10 mins a day
Incinolet Marine Toilet -- 1800 watts @ 110v -- hour a day
Please let me know if I need a larger battery bank? According to the data sheet for the 12V5KW it's perferred battery bank size is between 800–2400 amp hours, looks like I"m sitting at 1380, less losses because these are used, and I have not had the chance to load test them yet I'm picking them up on Sunday, but if I need more let me know
Would I need to run 2 of the inverters in "Split Phase" mode in order to get my 220v or could I get a 220v and split it into 110v outlets??
Is my battery bank large enough to run these items for these times??
Do I need to get special alternator for my Ford F250 Diesel Tow Vehicle?
Is my MPPT controller large enough to allow me to expand my solar system in the future if I can get my solar awning constructed ( supposedly will equal to 6 more of these panels )?
This is a complicated ask and I am more than willing to pay for some assistance if it comes to that. Cheers folks and appreciate any feedback.
"Tow Vehicle"
BMV-712 Smart
VE.Bus Smart Dongle
"Battery Bank"
"The Generator"
or
