flashboiler
- Mar 13, 2020
- 3
Hi all,
I just finished building my 1st LiFePO battery. 4 105ah cells following Will's video
Connected everything and it works!
Power supply charge voltage and BMS settings.
I'm using a desktop power supply to charge the battery. What is the recommended voltage to charge the battery to? I've heard 14.6V (3.65 per cell) but then I've read to use a lower voltage to maximize battery life. What's a good power supply voltage to charge to for decent battery life?
Also, what values for "Cell over voltage" and "Cell under voltage" do you recommend for long battery life. I'm not concerned about getting the max amphours per charge as my battery is now overkill for what I need.
Long term storage (6 months or so) I envision hooking up the bench power supply and setting to a voltage and let the BMS maintain cell voltage. Is this a decent plan? (Say set the bench power supply to 14.6 volts and just let the BMS keep the battery topped off. Is there a better (Lower) voltage to set the power supply for long term storage?
Thanks all, I tried to search the forum and google for above info but didn't have much luck.
