BondJmsBond
Hopefully you fine folk can guide me.
The 2/0 awg connection to the fuse used in this
Appears to be a jam the raw ends of the stranded wire in the round receptacle and crank the allen head screw down on the strands kind of deal.
I don't care for this, as I think it may damage strands and lead to an inconsistent wonky connection. As it's a very important connection I need to do it right.
I saw another thread mention a ferrell. Do I need one and also a crimper for this?
If so, where might I find a proper ferrell and a good crimper?
Or, conversely, is there a way to connect a lug to this fuse? An adapter?
Thank you for your help.
48V Offgrid Solar Power System
If you wish to build the ultimate offgrid solar power system, look no further: All-in-one units make setup a breeze. Each unit has it's own Inverter, MPPT, Transfer Switch and Battery Charger. Budget...
www.mobile-solarpower.com
