2 Duracell Golf Cart batteries, 6v GC2 AGM, spec sheet says it yields 103 @1 amp hour rate, the lowest on the sheet or 220 @ 100 amp hour rate, highest on the spec list. I know temperature affects output, battery chemistry has limits.
Now the total draw down ah on these 2 6v AGM is less than one generic 100 ah LifePo4, correct?
Trying to decide if I need 100 or 200 ah LifePo4 to power my camper van, guessing 100 ah LifePo4 is enough.
In Maine's winter will probably need battery heater and of course low temp battery disconnect, so the coach battery might need to be supplemented by a charger to power the heating pad.
