Following W.P.'s 400W DCC50s for my van
Would I be better off running 2 instead of 4 gage, Or is that wasting money?
I got a roof entry gland But is there one I can buy instead to run multiple cables & wires through ?
Yes, I'm guessing 15ft battery to charger, Instructions say 4ga & also figuring battery to frame to charger ground
Just buying till spring thaw thin I'll install (no heated garage)
15' x 2 + 10 for routing around obstacles is 40'
I strongly suggest you don't use the chassis as the return path.
The resistance will likely be high and variable.
