I just bought 2 x cheap ($290 US) generic supposedly prismatic 12v 135ah slim form batteries from a fairly reputable seller that I intend to use in parallel. i understand they need be the same voltage before linking them. I’ve been charging them with a Victron IP67 25 amp charger with the llifepo4 preset.
I finding that one battery is consistently around .1 of a volt lower ( 13.5 vs 13.6) that the other after leaving them for about 12 hours each on the charger.
Can I discharge the higher voltage battery slightly to bring it to the same voltage as the other and then connect them in parallel?
