Off grid. Replacing 2200 watt 24 volt inverter. Current Dimensions inverter has a component failure resulting in 13 amp idle consumption. System is hard wired on both 24 volt input and 110 output to breaker box. Suggestions? Brand and model?
Do you need low frequency or is high sufficient?
Do you want/need an integrated transfer switch?
Do you want/need an integrated ac charger?
Do you need a specific low voltage cutoff?
Not sure about frequency. Whatever it is now.
No transfer switch needed. Have separate one in system
have charger in system already
low voltage cut off is in current System
This is a great unit.I think it has too many features for us. And hence the cost. I’m going to think about it though. Maybe I scrap parts in the existing system.
