Yep, as far as i could tell. Watched a amp meter and watt meter as the pump would turn off and on. Highest amp reading was close to 15 amps or watt meter of 1800 watts.Are you sure? Is that an induction motor, and how did you determine start-up amps?
I use an oscilloscope and AC current probe, so I can see the sine wave for however many cycles.
I've measured motors (e.g. window air conditioner) drawing 4x nameplate current for a fraction of a second, then running on 1/2 of nameplate current (under mild conditions, not working hard.)
Update, that is per each 110 leg.
