Louisvdw
- Dec 18, 2020
- 166
I have reports of the 200A model that was bought a month ago. They requested the RS485 to be added and that is how it arrived.Learnt from the seller "jaibaida" that the 200A version only has bluetooth communication despite optional RS485 & CAN communication claims on the product page. Can I still make use of your solution for Victron systems?
according to the seller, this only support bluetooth (built-in) and doesn't come with the option of UART. I think your mention is only applicable to the 100A versions.
The best option is to ask for it with the USB-UART cable option or the RS485 cable from them. Both versions work.
The older 200A model has the bluetooth as an external plug in model (my 100A model is like that as well). This runs of RS232 (claimed as USB-UART). If you have the external bluetooth only model, then you can set up the BMS with bluetooth, then unplug the bluetooth dongle and use that to plug in your USB-RS232 cable.
But if it is now as you say then if there is no RS485 option and only internal bluetooth I would buy one of the other models instead.
