Hi folks. I currently have a 5kW grid tie system that has 2 strings, one is ~170v the other ~260v. Obviously the system is useless during a power outage due to the grid tie inverter. We are experiencing more severe weather events and subsequent outages. I was looking at ways of using the panels if the outage dragged on, but can't afford a hybrid inverter setup. I have a 100Ah 4s LiFePo4 pack that I can use, and was looking for a way to charge this using the panels, which I could disconnect from the inverter if the outage was going to go on for days. I really only need to keep the fridge/freezer running and maybe charge a few small devices.
So I'm looking for a DCDC converter that could power my hobby charger. The only one I can find so far that can handle the 170v input is the Kelly KL-144DCDC-400-5 https://kellycontroller.com/shop/kelly-dcdc-converter/ It could actually charge the battery directly at 13.5v, but not to full capacity.
Are there any other converters that could do this? The charger can handle ~11-18v, and I'd like to charge at 20amps or so. I've read that a standard mains AC switching converter could work, but I don't think my panel voltages line up to either a 120v or 240v unit.
Thanks for any input.
(I am aware of the risks of high voltage DC and would isolate panels and take appropriate precautions where needed.)
