Entwicklung34
- May 20, 2022
- 98
Hi.
I'm new to all this, but learning a lot and enjoying it. All advice appreciated.
So I have 2x 100w solar panels (and about to add a third) mounted on a South facing 15degree roof in parallel hooked up to a 30amp controller and 1200watt inverter. For storage I have two 110ah solar leisure batteries also wired in parallel.
I've been using the system to charge a couple of phones/iPads and run a small TV for a few hours of a night (pulling about 25watts) and my son's Nintendo switch. It has been brilliant for all of this - really happy with it!
I've also now wired some wall lights into the system (2 of them at 9watts each) and my wife has recently started using these of a day whilst working from home. She also charges her laptop on using the solar via a plug socket I put in for this purpose.
Looking at the wattage for all of the charging and lights I was expecting to have plenty of energy stored in the battery to cover a few shady days if needed and to be able to power more lights etc with this but today the solar cut out and the inverter turned off, I assume because of low voltage. The controller was showing 12.1 when I looked and it does charge up to 14.4 when full iirc.
I'm wondering if my expectations of this system are a bit too high?! I planned to add a couple of plug sockets upstairs just for lamps in a couple of bedrooms, but not sure whether it could handle any more at the moment.
I'm thinking I need to angle the panels up more to around 30degrees and add my third panel to get the batteries charged back up quicker.
Any other thoughts/comments I would really appreciate as I am really enjoying the mission of achieving some off grid power!
I'll add some pictures below of what I've got set up so far...
