underdog5004
I'm trying to find a compact transfer switch that can handle 240 volts split phase with a minimum amp rating of 20 amps. I've called Schneider and Eaton, but they're offerings are either too expensive or too large. The load will only be about 15 amps. Does anyone have any recommendations for compact transfer switch that meets these requirements? Two pole is fine so long as there's a neutral bar in the Box. This unit should be an on-off-on type.
The purpose of this transfer switch is to allow me to change the power source for my hot water heater from grid power to power from my solar system. I have more than enough power in the spring summer and fall to run the hot water heater from my solar system, but in winter time I simply won't have enough production.
