220 volt inverter?
GLC
Texas
Just seeing what may be good or bad inverters on the market in the 6000 to 8000 watt range?
48 system volts?
Do you mean 220VAC@50hz or 120/240VAC@60hz?
BTW did you test the temperature probe?
48 system volts?
Sorry, the feed from batteries would be 24 volts. This would feed well pump so i am thinking 120/240 volts. Crap, forgot to test the probe, will do it tonight.
6000 watts * 1.15 conversion efficiency / 24 volts = 287.5 dc amps.
That is a lot of current and will require 4/0 awg cable and a special bms configuration or multiple batteries.
Aims or Sigineer should have inverters that do what you require.
I suggest 48 volts.
Oh and the inverters I suggested are low frequency with significant peak capability which requires and even beefier current path.
You may be correct. Just did want to start over on controllers. Running now 2 ,40 amp 24 volt controllers, with 4 12 volt lithum batteries
