I know you aren't supposed to do it, but if I have a 240V A/C unit that uses split phase US 240V and does not use the neutral wire, can I power the A/C compressor with a 230V single phase Euro inverter.
The reason I ask is that 230V Euro inverters are a tad cheaper than US split phase inverters of the same power. If I dedicate it to the appliance, it shouldn't be a problem as long as it works.
Has anyone tried it? And did it work?
