deeperblue
Hi,
I am planning the build for my RV.
When building a 24V/28V battery bank, can I build 12V banks using 12V 4S BMS and then put them in serial?
I guess using 8S/16S BMS to directly build 24V/48V is always better, but there are a couple of reasons I would like to put 12V banks in serial:
1. To build my whole system in different stages and make sure the whole system still works between different stages, initially I need the battery banks to be 12V. (or it will be a lot easier for the whole process if it is done that way)
2. Parts are easier to get (like get 12V heating pads to heat the batteries during freezing weather.
3. Individual banks are lighter, easier to move/install.
So can I use 12V 4S BMS and then put them in serial? Does all 12V BMS support serial configurations? What's the main disadvantage of doing so? What do I need to pay attention to when building such system?
And what are the good BMS brands?
A lot of questions. Thank you very much!
