Fibonacci727
- Jul 21, 2022
- 3
I have 2 sp003 rockpals solar panels and I’m currently building a camper
For the moment I need to make use of these panels and make them work with a victron MPPT to charge a 4 cell EVE 280 12v bank, which I haven’t purchased yet.
The questions are:
Will the panels (24v) be better suited for this in series or parallel into the MPPT?
Will I be losing a lot of charging current by running these panels at 24 or 48v into a 12v battery?
Which Victron is most appropriate for this?
Do I still need a BMS?
Does victron make a BMS that harmonizes with their MPPT?
Will it be more efficient (albeit much more expensive) to run a 24v batter setup?
Any inverter recommendations for this setup? 2000w ish pure sine…
Is there anything I’m forgetting about?
【Prime Day Deal】Rockpals SP003 100W Fold Out Solar Panel
Rockpals 100w foldable solar panel 3 usb ports, high conversion efficiency, compatible with most solar generator, ideal for outdoors & any unexpected power outages.
www.rockpals.com
The questions are:
