John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
I don't ever plan to use lead acid batteries so I'm not well versed on the peukert effect.So, when you run your electric kettle on solar power, do you have a battery monitor that will watch how quick the battery % goes down?
I guess what is getting me is watt hours is one measurement and should work well for things close to a C20 draw, but for my 478 Amp Hour System at the C20 rate, once I draw amps much quicker than 24 amps per hour, like the 141 amps per hour rate, the math I’m doing says that when I run my kettle for 5 minutes, that will cost me 8% of my battery power If the C1 rate of the battery is 143 amps. Between some of this amperage coming from the panels in the daytime (in my favor), and system losses (not in my favor), this 8% should at least be a ball part number.
I was convinced before I came to this forum that going with a 2000 watt inverter was a bad and dangerous idea on a 12 VDC system. I’m trying to use some math to see with proper sized wires like 2/0 and flooded lead acid batteries, this could be done.
If we got a 2000 watt inverter, the other people in my family would appreciate The switch to solar, but with a 1000 watt inverter, they’d miss some things. My idea of camping is a little more rustic than there’s.
For lifepo4 its not a significant issue nor is round trip efficiency.
