Henry's Cat New Member Joined Nov 30, 2023 Messages 6 Location Uk Jan 13, 2025 #1 Would it be best to buy a 24volt battery, Or to buy two 12 volt batteries in serial.
chrisski Solar Boondocker Joined Aug 14, 2020 Messages 6,246 Location Central AZ Jan 13, 2025 #2 A single 24 volt battery
wiseacre Solar Addict Joined Aug 8, 2021 Messages 623 Location North of the Adirondacks Jan 13, 2025 #3 chrisski said: A single 24 volt battery Click to expand... Yep Best practice is to use the same battery voltage as system/inverter voltage Using series connected batteries introduces the complication of keeping individual batteries balanced
J JJJJ Aspiring apprentice Joined Feb 25, 2021 Messages 1,596 Jan 13, 2025 #4 What are your power requirements?
Q-Dog ¯\_(ツ)_/¯ Joined Dec 22, 2020 Messages 3,825 Location South Louisiana Jan 13, 2025 #5 Henry's Cat said: Would it be best to buy a 24volt battery, Or to buy two 12 volt batteries in serial. Click to expand... Yes.
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 25,450 Jan 13, 2025 #6 Henry's Cat said: Would it be best to buy a 24volt battery, Or to buy two 12 volt batteries in serial. Click to expand... If lead acid, either is fine. If BMS controlled batteries, the correct voltage for the system is always recommended.
