240 Volt All in one Inverter question
Johnnys
So I just finished watching Wills video on diy solar system
And I am leaning to buy the
Growatt 48V SPF 3000TL LVM
3KW OFF GRID INVERTER
Or 24V version
My question is does these units do 240 volts? I am planning to charge my Tesla?
Thanks
According to the link: You will need TWO units to form 240VAC Split phase 240VAC.
This is how they need to be wired, all videos are incorrect
OP is asking about 'SPF 3000TL LVM' not the 5000ES as shown in PDF.
SPF 3000TL LVM does not take 240V input, output is also only 120V, thus required two units to form 240V split phase output.
Or 24V version
Thanks
Good video on how much Solar is needed to charge a Tesla
You should remove that diagram, it is not finalized since it is still wrong and needs to be corrected. If L1 or L2 of the utility touches the chassis, the utility breaker will not trip when fault current occur.
See this thread:
