Robert T
I'm planning on putting a 240v Emporia level 2 EV charger on the AC-Out-2 of my 12v Quattro II 3000 2x120v Inverter. This will only be available when I'm hooked up to shore power and the inverter is in passthrough mode. I'm aware that I will probably have to limit charging to 32A since the connection maxes out at 50A/240v (edit: the Emporia maxes out at 48A) and most RV outlets don't do very well at max rating continuous. The Emporia has smart load management which should work well with this setup. I was planning on putting a 40A breaker on my charger.
Any advice would be greatly appreciated! Can anyone think of any problems I might run into with this setup?
Thank you, I <3 this forum
[edit] for clarity my RV has a standard dual phase 50A inlet.
