I’m learning about the capabilities of V2L/V2H cars of the current model year to see if it’s worth buying one of those cars instead of building or buying a backup power system for my house. I am aware there will likely be more options once bidirectional CCS is on the market, but that’s kind of too abstract and theoretical (a 2025-2030 thing). The ones on the market right now are just a tad shy of a good fit for my requirements. (Eventually) this post will get to whether there is turnkey solar / battery storage hardware that can be used to bridge the gap. The car I’ll investigate here is the Ioniq 5, which in North America outputs 3.6kW split across two 5-15R (*note: I'm not sure if 3.6kW capacity has been confirmed by users yet, I'm going by what I consider non-authoritative sources, namely car reviewers and the PR announcements from Hyundai).
I believe KIA/Hyundai E-GMP cars (Ioniq 5 etc) and F150 Lightning are the main MY 2022 cars that support V2L in North America (Chademo cars are bidirectional but I don’t believe the hardware is easy to buy in North America). I have no need for a Lightning, so that leaves just the Ioniq 5. With V2L the most viable topology is manual transfer switch for backup power, although it’s probably possible to hack something together with OpenEVSE and a hybrid inverter to achieve grid tie and fast transfer to standby power.
So let’s assume backup power case. For my house, I could probably fit backup gas heater, computers, and refrigerators on a 120V critical loads panel. However, I would not be able to start the primary air handler to circulate that heat, since that power is provided on the 240V mini-split circuit.
This car has two 5-15R, one in the cabin (on Limited trim) and one in an optional accessory that plugs into the J1772 port. In Europe and Korea the charging port (IEC and J1772, respectively, AFAIK) are ~230V L-N @ ~15A.
Obviously the overseas adapter might be used with a transformer to form 120/240 @~3kW (what efficiency might I expect). If it works, this has the advantage of working with the lower trim models. So let’s set that aside for now, I don’t think anyone in North America has gotten their hands on one yet.
So with the officially supported North American config, I could use an autotransformer to step up one of the 5-15R to 120/240 with <1.8kW capacity. That could allow the mini-split to boot up, but would be well below the MCA. It would have to be started in circulate only mode. Maybe it'll work...
Another configuration is to have two separate 120V critical loads panels, each with a transfer switch and connected to the car. This would waste a lot of space in the panels, but is easy. Not sure if this is code compliant...
So to get enough power to safely start up and configure the circulation fan (and perhaps even run the mini-split at low power, in conjunction with the backup gas heater), it would be great if I could combine the two 5-15R. However, I’m not sure what the best topology for this would be. I think it would have to be DC coupled, since we cannot trust how the inverters on the car are arranged (no guarantee that they’ll stay in sync, etc etc).
To achieve the DC coupling, I believe I can use current sharing power supplies:
6 to 8 Meanwell SDR-480P-48 48V/480W DIN mount, 3 to 4 connected to each 5-15R ($170 each)
https://www.meanwell.com/productPdf.aspx?i=811
These are UL 508 listed, which I assume is robust enough for home use.
The 48V output of these can then go into a standard off-grid 48V->120/240 inverter, which then feeds into a transfer switch.
Are there other ways to configure this? Is there an automatic transfer inverter that can be used instead? Perhaps there's an interesting config that uses the in-cabin 5-15R to feed into a solar system, while the car is fed power via L2 charger. This would not be able to power as much standby load, but it could be used for things like peak trimming, (very slow) arbitrage, and guaranteed carbon-free operation overnight.
