Shale MacGregor
- Sep 5, 2021
- 641
This seems like something simple that has been done before, but apparently I suck at searching.
I want to measure the voltage of a battery, and when it hits a certain voltage (full charge) it triggers a 240VAC 50A relay. Then when the voltage drops to a certain point, it triggers the relay again.
I am pretty sure I can plan and build this, and will, but I figured I am probably overlooking a simple existing solution or product that is out there and would rather spend the time on something else.
