24V 100Ah vs 2X 12V 100Ah battery for 24V system?
questrov
24V 100Ah vs 2X 12V 100Ah battery for 24V system? What are pros & cons? Which way would you go?
sunshine_eggo
Happy Breffast!
USA
24V 200Ah has 4.8kWh of energy storage
24V with 2X 100Ah 12V in series has 2.4kWh of energy storage.
2X the storage. Since money isn't mentioned, moar capacity.
questrov
Oops, edit! Should be 24V 100Ah. Same capacity, discharge, etc I believe.
Ampere Time 24V 100Ah LiFePO4 Deep Cycle Lithium Battery, Built-in 100A BMS, 4000+ Cycles Rechargeable Battery, 280A Max, Perfect for RV/Camper, Solar, Marine, Overland/Van, Off-Grid Applications… https://www.amazon.com/dp/B08P6LP1J...abc_RQV366Q81PMWQ3Q7QQNH?_encoding=UTF8&psc=1
Ampere Time LiFePO4 Deep Cycle Battery 12V 100Ah with Built-in BMS, Perfect for Replace Most of Backup Power and Off Grid Applications... https://www.amazon.com/dp/B084DB36KW/ref=cm_sw_r_cp_api_glt_fabc_3AP1JM9YSYV0S9Z1SBDJ?psc=1
sunshine_eggo
Happy Breffast!
USA
24V. All 8 cells are managed by the same BMS ensuring cell balance.
12V can only balance within themselves. The 12V batteries would need to be top balanced in parallel periodically. From:
If your batteries are in series and not being charged by a multi-bank charger it is recommended that you fully charge the batteries individually once a year. This will balance out the entire battery bank to ensure the batteries will reach its expected life span.
indalecio
one BMS control one battery pack unit is easy to handle. but if you connect them in series, MAYBE, there will be potential problem. because you connect in series 2 BMS.
more simple with less problem.
50ShadesOfDirt
Nobody ever expects a battery to fail, but if one does (bad bms), it's possibly a bonus if your battery bank configuration can be reconfigured with less Ah, vs being dead in the water while a battery is being warrantied out.
schmism
Central IL, USA
that is not an option with only two 12v batteries in series.
Put me in the a single 24v battery camp.
