Diesel Pro
- Jul 21, 2021
- 112
I started looking at Big Battery but too many issues. Also considered Chins/Ampere time. Neither of these had decent monitoring or low temp charge protect so now I am looking at building my own. Given proper instruction I can build about anything. My hang up tends to be analysis paralysis so I am floating this out there in hopes that I get some good guidance. System specs at the bottom for reference. The system and capacity are far beyond what is needed but allows for increased demand.
Looking at building a 24v 230ah battery. Could potentially be swayed to or down a touch in ah rating based on bang for buck.
Looking at Eve cells from one of the China/USA suppliers highly regarded here
6000 cycle rating: Seems many are adopting this standard. I’ve tried to research this and it seems that there is no real change to the construction it’s being used more as a marketing ploy stating the best case scenario?
BMS suggestions: I’d like a good monitoring setup be it a heads up display or a Bluetooth. The Daly BMS seems to come up a lot in searches. I was looking at this one: https://www.amazon.com/gp/product/B09798DWWR/ref=ox_sc_saved_image_1?smid=A22QWF3YLLYB17&psc=1
Containment: I was thinking I would build into one of these Noco boxes: https://no.co/hm462
It’s a whole lot taller than I need but 2 groups of 4 cells in a block configuration should fit nicely.
Off Grid cabin unoccupied 350 days of the year. My system is much oversized for what we normally do. Has heat to keep from freezing, but standing pilot can go out so low temp charge cutoff on BMS would be required.
Magnum 4024 Inverter
Midnite Classic 150 charge controller
4x 320w Solarworld panels
430ah 24v wet battery bank-these are 4years old and now cooked
Parasitic draw for inverter, television, microwave, and a small fan in the partition wall that moves air from room to room. Amp draw of these loads does not show on the Magnum. The issue with wet batteries is not being there for weeks or months at a time and finding the right balance of sufficient charge voltages versus water cook off.
When we are there we run very little load 99% of the time. I have a small air conditioner that I run once a year to make sure it works. Otherwise it’s on standby. Microwave gets used here and there so that’s the most common large load. During maple syrup season I bring my Honda EU2000 generator so I can power my reverse osmosis. This is probably up around 1600-1800watts. On occasion I have run the R.O. on the battery system just to test and exercise it.
