I'm planning the electrical system for a narrowboat that I will start the build of later this year. I plan to have a 24v LifePo4 domestic battery bank built from Eve cells (either 8x280Ah or 16x280Ah 2P8S - yet to be decided) with a JK BMS and I would be interested on any thoughts on my possible system to charge these with an alternator from those more experienced in these set ups.
I plan to add a Mastervolt Alpha Pro III regulator to a 24v 100A alternator to temperature protect the alternator and to provide a 'small engine' mode for use at tick over speeds. However this does not protect the alternator from possible BMS charging disconnects that will blow the alternators diodes. I will however have a Victron Cerbo GX onboard and this has a relay output for starting a generator. The start and stop voltages can be adjusted on this so my thought was to use this to turn on and off the alternator regulator (perhaps via a solid state relay). So if the pack voltage gets to say 28.0 volts (3.50v per cell) then the Cerbo GX will turn off the regulator. I can then set a lower level for voltage to drop to to turn alternator charging back on. As long as the Cerbo GX's turn off voltage is well below the BMS maximum stop charging voltage the alternator diodes should be protected from any load dumps. I will also have a large solar array so I don't really need the alternator to be charging the LifePo4 to fill the last few % so these Cerbo settings could possibly be even a little more conservative.
Obviously there is an issue if the cells go well out of balance and one cell hits the 3.6v BMS stop charging voltage before the whole pack reaches 28.0v . The JK BMS has a powerful balancer built in so with well matched cells this shouldn't happen however in the event it does I plan to also have a Sterling alternator protection device (APD24) attached to the alternator. Sterling tell me these should not be used for protecting an alternator on an every day every charge cycle basis but are fine for occasional protection.
My engine starter battery will be 12v lead acid so I could simply charge that with a 12v alternator with smart regulator and then use B2B to charge the 24v domestic bank but this seems inefficient and has limited output and is also rather expensive compared to just using the Cerbo GX that I already have.
Yes I could buy a different BMS that has a relay output that could be used to turn off the alternator regulator but they all seem to a lot more expensive than the JK BMS.
Your thoughts would be appreciated.
