Yes but you have to understand that I designed & built my home and did so with Efficiency in mind because right from the start (even before buying my land) I knew I was going offgrid solar powered with this build... It's my final build and my Bucket List item I wanted to do and I had a lot of time to plan & implement it.
- 1 bedroom, Full Bath, 2nd story loft, 9/12 pitch roof (Cathedral Ceilings)
- FPSF Slab Foundation R-20 HD-Foam Insulation under it & up the sides.
- Radiant Heating in floor with 7/8" Pex
- Cool Roof System (saved 25-30% of Heating & Cooling costs and is incredible ! (Thermally Broken Roof)
- Rain Screen Siding method (used Live Edge White Cedar as my finish) (Thermally Broken Walls)
- INSULATION: (All obtained from Commercial Roofers - not available in retail land)
- -- 4" XPS Under the FPSF Slab and out the sides (wings) 24" providing R20, double code requirement.
- -- 5.25" High Density EPS-2 Foam between 2x6 studs R32)
- -- 7,5" Paper Faced PolyISO between Rafters (Cathedral Ceiling, roof is 9/12 Pitch)
There is a lot more info but it does not belong in this thread. Bottom Line, is that a well-built efficient home that uses Passive Technologies to maintain its livability is far cheaper than Generation & Storage and has an immediate payback in comfort & affordable livability. The passive airflow between the RainScreen Siding & venting through the cool roof via natural convective forces os not new and is extremely effective.
Fact is, my Heating System runs for 4 hours per day to keep 25C/77F Temp in house even when it is -30C/-22F. Additionally, during summer the Radiant Slab is a Thermal Regulator which never goes over 19C/62F and therefore keeps the home cool which the Thermally Broken structure which prevents heat transfer into the house from outside.
