jvbutter01
- Aug 20, 2020
- 208
In my TT, I am adding 2 - 12v lifPo batteries in series for 24v. I will have a 24v inverter mounted close to the batteries to supply the 110v for the power center. I can't have just 24v in the trailer. I have many motors that use 12v. Is there a device to easily step down 24v to a 12v output for power station. Keep in mind, the batteries/inverter is in front of trailer and 20ft to the rear is the 110v/12v power station. I do see there are many 24v to 12v converters. I worry about the amount of distance if I keep this 24v-12v converter in front.
would the best bet have 24v batt / inverter in front, sending 110v to the rear power center. at the power center, mount a 110v to 12v converter for the 12v motor needs?
Keeping 12v from start to finish will require upgrade in the main DC cable's from front to the rear, as well as increased hazard of pushing 150a front to rear. 150a max current for my 3000w inverter planned install.
idea of 24v to 12 came from will to use a 24v to 12 conv at the rear power center
RV Solar Power Blue Prints
Building a vehicle mounted solar power system? Let me help.
www.mobile-solarpower.com
