Argh .... my head is spinning from reading and trying to finalize my (fulltime rv/avid boondocker) setup.
Here is what I have : 8 x 250w Trina panels permanently flat mounted on the roof (ocv 37.6v, pmax 30.3v, scc 8.85a pmax 8.27a) currently wired in two sets of 2s2p.
Two temporary 110ah12v deep cycle batts but plan on replacing with a (most likely) 8-12 x 280ah lifepo4 diy bank on overkill bms (2-3 groups of 4s/bms if I go 12v).
I understand the benefits of 24v, especially when it comes to $$ of the controller(s) needed, but it seems 24/12 converter(s) add almost as much $$ as I save in SCC as well as adding more complexity ?.
So my (latest) rest of the setup would be twin outback fm60a and a victron multiplus 12/3000 (what is imho a decent "bargain" for a lf inverter/charger/transfer switch)
Any and all input/ideas/suggestions is highly appreciated ?
