gmcconnell
- May 24, 2021
- 24
Hello!
I have a question that I think I know the answer to, but wanted to make 100% sure I didn’t have something backwards because it has been confusing me a little.
I am drawing up some plans for solar on my Airstream. I’d like to use a 24V system and around 200Ah. I want to be able to power a 3000W inverter so will need over 100A to do so.
I’m looking at the SOK batteries. I am planning on running 4x of the 100Ah batteries in a 2S2P configuration. I figure this will give me a 24V 200Ah battery capable of outputting 200A.
However, I just wanted to make sure that was how the BMS works. I understand the battery capacity is added when paralleled, but is output also?
I would like to buy 2x of the 12V 206Ah and run them in series to save $220 but I think that will only output 100A, correct?
Or buy 2x of the 24V 100Ah and run them in parallel which will also save the money, but would output 200A if I’m thinking of everything correctly. Unfortunately I don’t know when/if they will be back in stock. Anybody have any insight?
Thanks everybody, learning a lot on here!
