complicated and looking for advice.
. 28v/14v 200* amp/50amp alt. on engine (yes dual voltage) will use 28v side for charging probably to primary 24v wet battery bank on engine first and house lithium battery second (yup military truck based camper) Yes truck has 12v accessories and lighting. Its 24v series/parallel wired batts get 12v pulled of one bank of two bats... I can add a balancer to prevent one bank getting harmed by this (not yet installed-- unit does NOT work with Lithium)
. 28v/14v 100 amp/50amp alt. on APU (yes dual voltage) will use 28v side for charging.... back up for cloudy day... top up.... again primary engine batts first.... then house
the alts both go up to 32v or 16v... so they need limited to not overcharge into lithium... again only 28v side for lithium house charging.. both have thermal protection of some sort on external regultor.
would like to NOT duplicate things to use APU alternator
. 1000w solar panels (already purchased) but do not yet have an inverter charger or anything else for that matter.
* technically up to 50 amp max on 12v side of each alt. is robbed away from the max amp output at 28v on these alternators.
sooooo what are options for also charging house and start batteries with solar AND alternators. Seems so far all I can find limits my use to half the potential of the 200amp alt at 28v side... that is sad. Paid a good bit for that alt. to only find out I may not can use its potential
