Newbie question, sorry....
I plan on using Growatt 24V SPF 3000TL LVM - 3kW inverted and 2 12V 200AH batteries. Each battery has a 100A BMS, so .. if I connect them in series to get 24 Volts , the max supported draw would be 24V @ 100 Amps. Pleaseeeee correct me if I am wrong.
If the above is true, Would I need 2 guage wire to connect the batteries in series and from the batteries to the inverter?
Thank you!
The Rookie
Thank you!
The Rookie
