You mean the 12 volt battery?
I don't know how the legacy scc is wired.
I don't think we have discussed how you plan to integrate the legacy SCC.
legacy system is as so: solar panel -> SCC -> 12v FLA battery
I have removed the old solar panel and will be removing the old SCC as well.
My plan now with the orion is: lynx distributor -> orion -> 12v fla battery
Powering the ac2dc converter from the inverter is brutally inefficient.
If that is ok with you it makes the wiring much easier.
Well I would like to have power to the dc distribution when plugged into shore power still. Is there a way to allow the ac2dc converter to work when plugged into shore power and disabled when inverting?
I propose for a test that you disconnect the tongue battery and see if the ac2dc converter can power the jack.
If it can then I think the dc2dc charger is not required.
The tongue battery will be charged by the 7-pin cable when you are towing and by the ac2dc converter when you are on shore power.
The legacy SCC could also be charging the tongue battery.
ok ya but I have decided that if I cannot use a 24v to 12v dc2dc converter to power all my dc appliances then I am just going to get another 12v battery dedicated for the DC side of the system. I need to have dc power 24/7 because my fridge is run on 12v dc only. Cannot be powered any other way. And I live out of my rv so I always need the fridge on. like in the scenario that I run out of power from the 24v battery bank, I would like to have the 12v battery bank still available.
I have had the DC side run off of this existing battery for almost a year now without issue so I figure why change that if it is going to become a hassle to wire into the new system.
The only caveat being that I am not charging that 12v FLA battery with the solar/scc anymore so the orion seems to be my best bet for keeping it charged.
We need to talk your solar strategy.
4* 250 W panels in series parallel connected to a victron smartsolar 100|50 scc connected to the lynx distributor.
Since the legacy battery is being charged by the ac2dc converter, tow cable charge line and possibly the legacy scc I don't see any issue at all.
The dc distribution panel will be energized by the ac2dc converter which is inefficient but otherwise fine.
The legacy battery is charged by the solar panel and scc. the battery powers the DC distribution panel unless connected to shore power, in which case the ac2dc converter powers the dc distribution panel and charges the battery. That is the legacy setup.
What I am trying to figure out is that I am removing the old solar panel and scc and the new solar array and scc will only be used to power the 24v battery bank at the moment. Can I use the orion-tr smart 24/12v dc2dc charger to charge the 12v fla battery through the 24v battery bank instead of the legacy solar panel and scc?
