Hi Folks, So if I desire a Grid backup system, where usage "Should" only be limited each year, which is best, 48v vs 24v. I have read that 48v is more efficient but I thought that if I decide to add a couple solar panels as a emergency charging source 48v would require more of them to do the job... I also see a battery which specs like this: 24V 202 ah- 5.2 kWh VS 48v 103 ah - 5.3 kwh. So the Amp hours are about double for the 24v bit the kWH is about the same. And the 48v is only $200 more. What do you think. Again this is for a limited use Whole home (of course limited use during an outage) backup. (the biggest draw is my jetpump)..
Thanks for your knowledge!
