Hello All
Unlike other threads I Pay for real advice.
I will send via Venmo 25 bucks to the first person who can answer this question.
I have 3
250 Watt solar panels that are tied in tandem and that i am using to maintain the charge on a 12 volt lead acid battery used to power a washer.
I have been told in need to place a "battery charge controller" between the solar panels and the battery to prevent over charging.
the question WHAT SIZE (charge controller) DO I NEED??
additional information on the panels I'm using.
max power --- 250 watt
open circut voltage --- 37.6 volts
voltage at pmax ---- 30.3 volts
short - circuit current --- 8.85 amps
current at Pmax --- 8.27 amps
max system voltage --- 600 volts
fuse rating --- 15 amps
I have 3
