My system is up and running for a few days and at mid-day, with full sun, and a clear sky, I’m seeing the inverter reading of about 2600 watts input from 4000 watts of solar panels. Below are more details. Your thoughts would be greatly appreciated.
Growatt SPF 3000TL LVM-ES-48 Inverter
Max. PV Array Power 4000W
Max. PV Input Current 18A
PV Array MPPT Voltage Range 120Vdc~250Vdc
10 Panels, 400 Watts, 7.59 amps, 48 volts each.
(Used – Solaria, PowerXT-400R-PM)
5 panels in Series – Then 2 strings in Parallel =
15.18 amps, 250 Volts, 4000 watts each
(2)EG4 48volt Batteries
South Facing – no obstructions
Panels are clean
The tilt angle of the panels is 21 degrees
10 gauge wires from Signature Solar
At the time of reading, Inverter says batteries are 70% full
The outside temperature is about 100 degrees Fahrenheit (panels must be at least 180 degrees since my building siding is nearly 150 degrees)
I tested each string of panels with my multi-meter both are producing power equally.
Panels are clean
