Would it be reasonable as a rule of thumb to calculate the watt hours of a LiFePO4 280ah 4s like the following? You could get cells that a bit lower but just thinking about some default calculations to add to a spreadsheet.
Utilize only .80 of the battery as to not drain all the way down and .85 efficiency with use of an inverter. I understand that with lithium you can run all the way down but still seems that a floor of 20% should be reasonable limit before the lithium curve drops off.
Realistic watt hours?
280ah x 12 v = 3360w x .80 = 2688w x .85 = 2284.8w
