Anyone seen 280Ah EVE cells with terminals like these before? I just received them from Aliexpress seller Tewaycell Battery Store.
The step at the bottom is just over 8mm diameter, my M8 cable ends will not go over it, while of course M10 ends are very loose. The bolt is a standard M6 diameter not that that helps at all. The bus bars are great, but don't fit!!
I've talked to the seller who just contradicts me and tells me this is normal. But I don't see a good contact happening without some fiddling/grinding/drilling.
Haven't tested them yet, just charging them (slowly) now.
Should I dispute this for a partial refund?
Best way to fix this??
For reference I've included one of the listing photos which looks quite different I think.
