mrdavvv
- Jan 14, 2020
- 404
Hello.Thank you @mrdavvv - the little black things near the positive terminal are midi fuses. I thought it made sense to fuse everything seperately so that if 1 fuse blew I still have other charging capabilities.
I thought the Victron Battery Protect was for load, so I only had it attached to the fuse box load so that it would shutdown access to appliance if the voltage of the battery was too low.
When you say battery disconnect, is that the same as described above?
I mean some of this:
Really useful for when you need to work in the battery, also safer.
