redmessengerbag
- Mar 15, 2020
- 41
why did you upgrade the bus bars, did the xuba ones run really hot?
I'm sorry to be that guy, but you have used heat-shrink terminals but not heated the shrink to seal it to the cables.
How much did the aluminum bus bars, nuts and bolts cost you and from where did you source them (especially aluminum nuts and bolts)?
Also, what conductor type are you using for the leads to the BMS and what material is used for the lugs on those leads?
Hi, Any links to the ebay items would be great, thanksEverything was from ebay UK, probably cost me £15 all in.
You're about right on the weight. The cells are 11lbs each. By the time you add BMS. Bus bars, bolts, washers, etc., you are probably close to that.Hello, how is this build going? Did the most recent diagram you posted work as expected? I am interested in building one of these for car camping to power a CPAP machine for several days. I think my current inverter is 750W, 500 running, but I'm not even using that, so very low amps. If anyone who has done this can give me a rough estimate on weight, by my calculations it's looking like roughly 46 lbs. for the batteries alone, that would be great. Also, I will need a charger as I don't have solar panels, so suggestions there also. Help for somewhat of a n00b please. Thanks!
FYI many companies uses 2+ cables inside a single "conduit" for better heat dissipation. Tesla supercharger cables have such a configuration.This was discussed earlier in the thread about the separate wires coming off the BMS. This is how I dealt with them.
View attachment 18956View attachment 18957View attachment 18958View attachment 18959View attachment 18960View attachment 18961View attachment 18962
