EnergySolutions
- Jan 14, 2020
- 11
Brand new, assembled in USA with new Japanese Panasonic-Sanyo cells. Wrapped in 2 layers of shrink wrap, with two layers of water resistant caulk on the side openings. The pack consists of two 13s3p packs put in parallel with a bms installed on each one for extra protection.
Satisfaction guaranteed and returns are always easy and welcomed.
DOES NOT COME WITH A CHARGER
Condition: Brand New
Weight: 10lbs
Connector: XT60
Cell Layout: 13 series 6 parallel
Measurements: Lenght:15.5" Width: 3" Height: 2.75"
Casing: Double layered Shrink Wrap for extra protection
Nominal Voltage: 46.8V (Max voltage 52v)
Limited Charging Voltage: 54.6V/3A
Resistance (23 ± 2 ℃): ≤ 250mΩ
Charging time: 8-10 hours
Cycle life: ~800-1000 cycles
Nominal Capacity: 21Ah
Watt Hours: 982.4Wh
Minimum wattage output: 1000w
Max Continuous Discharge Current: 30A
Amount of cells: 78
Cell manufacturer: Panasonic-Sanyo
Cell Size: 18650
Cell model: Panasonic-Sanyo NCR18650GA 3500mAh
BMS: 2x15A BMS's Installed (Low Voltage, Overcharge, Temperature, Current output and Short Circuit protection, with power equalization output)
Storage conditions: -15 ~ +35 ℃, relative humidity: 45-75%, atmospheric pressure: 86-106KPa
Use the operating temperature: Discharge: 0-60 ℃; Charging: 0-45 ℃;
Weight: 10lbs
Connector: XT60
Watt Hours: 982.4Wh
Amount of cells: 78
Cell Size: 18650
