So I have an AIO MPPT like Will Prowse does in his 24v setup.
My setup is also 2kw solar, and has a 5kw battery rack. So his walkthrough seems very direct and simple enough to follow....
BUT he never seems to talk about ground much? So I'm trying to figure out what I need to do for a camper about ground? My solar array will be mounted on the camper at first (but when I get to location I'll be setting it up on the ground).
I read that some say you need to run a wire (from where?) to the metal frame of the trailer. But the camper is designed to be removed from the trailer....
Then I also ready you definitely SHOULDN'T do that? Hmm
