I’ve been running of 6 months with a 2P configuration with great success except for the 300 Daly’s current sense has gone nuts. It can swing 2X actual current and back again(see screen grab). This has lead me to adjust the bms’s settings higher than I like since it wants to trigger a false over current and shuts down the inverters. There’s software to fix it but not good one for the 16s bms. The software I found for 16 looks flaky and may kill the thing with my luck, leaving me dead in the water. So I’m considering retiring all the 2P jumpers and going back to the #2 diagonal jumpers and having two batteries with two JK bms’s 2amp balance 200amp load(ordered,due 9/9/22). Cells are CATL 305ah Heltec retired now with Neey balancer(to be retired also).That changing around makes me glad I didn’t spend all the time straightening all the spaghetti lol.
But hear’s the catch. The cells have been compressed with 550 lbs of force (10psi) and a .040” silicone spacer between them. The spring maintains the force during minor cell expansion and contraction. The cells were reasonably flat on the sides and all looked and still look close together. In order to reconfigure the cells, I’ll have to release the clamping pressure (at low SOC) and rotate half the cells. So my question is, do you think it’s safe and not harmful to molest the cells?
