I've never liked XpYs configurations.. There seems to be more points of failure than YsXp with multiple BMS. If any of the bus bars in the parallel pairs has a higher resistance connection, you can end up with a badly behaved pair. If any single cell decides to fail short, you're shorting its partner through it, which is very bad news. Each cell of the pair sees potentially different (no pun) resistances in the bus bar network to its partner, as it has an extra bar and extra connection that its partner doesn't share. All this to save a BMS doesn't seem worth it to me. Add to that the mystery that you're now facing.. which of the odd pair is misbehaving and why? With only single cells per channel on the BMS, it's a lot clearer. You also have one point of failure with the BMS and many single points of failure at all of the interconnects in the battery. With YsXp, you've got a backup if one battery or BMS flakes out. You can take a whole battery offline and leave your setup running.
