buckeyestargazer
I'm building a 12v LiFePO4 battery using 8 EVE 230AH cells, and using the JK BMS 200A, 2A. First, I'm not sure on the "8S" lingo but I am planning to build it like in this video.
If I have 4 sets of two cells in parallel to make a 12v battery, will I still only use 4 (of the 8) balance leads from the BMS, one lead on one of the positive studs for each parallel set? Or is there a way I should be using all 8 balance leads?
