Due to space limitations on my RV, I want to run:
Both of those strings would be connected in parallel (so 2S2P) to a Victron 100/50 MPPT. I will be slightly over-paneled at peak output.
I could just go with 4x 180W panels but I would like the extra output if there aren't any downsides. All of the panels are mounted in the same plane and there will be no shadowing due to the RV (though there could be due to trees, etc.)
My thoughts:
Thoughts? Should I be good to go with the above arrangement? Seems like it since the voltages and cell arrangements among the panels match each other.
Tech info for 210W panels:
Tech info for 180W panels:
- 2x Newpowa 180W panels connected in series
- 2x Newpowa 210W panels connected in series
My thoughts:
- 2S2P might be good to deal with any shading caused by things around my RV
- Any losses in the wiring by going with a higher voltage 4S 180W arrangement will be more than made up for with the extra 60W of solar
Maximum power (Pmax) | 210W |
Voltage at Pmax (Vmp) | 16.77V |
Current at Pmax (Imp) | 12.48A |
Open-circuit voltage (Voc) | 19.83V |
Short-circuit current (Isc) | 13.09A |
Maximum power (Pmax) | 180W |
Current at Pmax (Imp) | 11.20A |
Open-circuit voltage (Voc) | 19.84V |
Short-circuit current (Isc) | 11.75A |
