burakcoskun
I have the following setup:
6 x 550 Wp Solar Panels (each with 49V)
2 x 48V 100Ah LiFePO4 batteries (Model: Aspilsan 48V/100Ah)
The batteries are connected in parallel, as shown in the photo.
Connections 1 and 2 are going to the inverter.
System Setup:
Inverter: 1x Tomatech MPlus 7.2K 48V MPPT Monofaz Inverter
Charging Voltage: 54.6V
Charge Current: 50A
Cut-off Voltage: 42V
Current Issue:
The solar panels are not charging the batteries when the grid is not available.
The house is being powered by the solar panels and batteries, but the batteries are not recharging.
The battery level is currently at 0% at the application.
The battery does not have a BMS
Battery Settings:
I selected USER as the battery type in the Tomatech inverter settings.
For this setup, should I buy an additional MPPT charger or an AC-DC 48V adapter to feed the batteries directly from the inverter's AC output?
Or is there something I need to change on the inverter to enable direct charging from solar → inverter → battery?
Thanks a lot for your time, everyone!"
System Setup:
Charge Current: 50A
Current Issue:
Battery Settings:
