jasonhc73
Cat herder, and dog toy tosser.
$700 Each, 2 total available.
$1400 for the entire setup.
Wichita Kansas
I am going another route with my configuration.
In configuration and used regularly and safely daily.
Currently used in parallel on split-phase 240V. 3 are possible for 3 phase setups.
Very reliable and very configurable.
WiFi and parallel cables kit included.
This setup can do 10K AC output continuous, supports four 4k MPPT DC PV inputs, for example, four completely separate strings of PV. 16K total possible of panels.
This is NOT GRID-TIED compatible.
You can use it GRID-CONNECTED or OFF-GRID. Grid-Connected means you can have it receive power from the grid, to charge batteries.
These will supply 240V,208V, or 120V, however you want to make it happen. It is very easy to configure. I have never once had a problem with these.
These only work with 48V system batteries. This will not work "batteryless".
Call/Text - 3one6-37one-4224, or pm through the system.
Wichita Kansas
