I'm building out a system with a Victron Multiplus II 2x120. My plan was to use a pair of SOK 206Ah (non-heated).
Min@SOK (and their product page) tells me that the BMS is rated for 130A continuous output, and this post has @jharrell saying they've pulled far higher continuous discharge rates, and charged them at well over the listed (50A) rate with no BMS cut-outs. 2400w/14v=200A, which is obviously less than the theoretical 130Ax2=260A rate. That tells me I should be fine, but then I see others posting here (and many on the SOK FB group) about struggling to run even smaller inverters off of two of these.
My order is supposed to ship out tomorrow so there's still time to change it. Should I be changing to 4 of the 100Ah SOKs instead? I'd really like to avoid the extra 18 pounds, $200, and considerably more physical space taken up by 4 batteries. If I have to switch to 100Ah then I'm going to be space-limited to 4. With the 206Ah I have space for a 3rd if I need more capacity in the future.
Thoughts?
Thoughts?
