Hello anyone, and hello Will,
I am looking at installing 2xGrowatt SPF 3000TL 24v into a bus conversion to potentially provide 230V to Mr.Cool dual zone A/C with softstart capacitor. I would like to retain the ability to still be able to hookup to 15/30 or 50A grid if possible. I was also wanting to use the cheaper LifePo4 batteries without low temperature protections, and provide those protections off-band using arduino or raspberry pi with integration to the inverter. I know some of these things would be possible with a Victron inverter. Now for the questions, can Growatt be controlled via WIFI without going through the "cloud". Can "Solar Assistant" do that, and turn off inverter charging on demand?
Can Growatt SPF 3000TL be configured for variable input amperage on demand without having to fiddle with the menus?
Thank you,
Thank you,
