steppinout
I want to connect three Siekon 12v 100ah batteries in series to a Ecoflow Delta 2 (with the extra battery). I believe this 36v system will maximize the 'siekon to Ecoflow' charging via a xt60i.
1. All three Siekons were bought at different times, will this be okay (they all have different amount of use)?
2. As I understand, before connect them in series I need to charge and balance them. I was going to put each one on the charger to top them off, then connect in parallel to balance. Is this correct? How long will they need to balance?
3. I saw a video where they connected the two batteries they were using into a balancing module (I think that's what they called it). Is that required?
4. Will my Delta 2 be okay with the extra battery and this 36v setup connected at the same time?
5. How do I charge my 36v system when it is empty? In series or in parallel? (My current charger only does 12v&24v so I'd need to buy a new charger... So is it better to keep them in series or will charging them in parallel work just as good?
6. I bought a 20amp circuit breaker. Can I install this in front of the xt60i?
Sorry for the 20 questions, any help is appreciated!!!
